Warning message in importing netlist
edward , 04-16-2019, 11:07 AM
I am in lesson 8 and tried to import the netlist but there are warning message that I cannot figure out how to fix it. here is the warning message. I need help how to resolve this warning message.
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol 'PAD_D4MMX1MM5' used by RefDes J1 for device 'PAD D4MMX H1MM5_PAD_D4MMX1MM5_4' not found in PSMPATH or must be "dbdoctor"ed.
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol 'MH_D7MM4_H3MM2' used by RefDes MH1 for device 'MOUNTING HOLE D7MM4XH3MM2_MH_D7' not found in PSMPATH or must be "dbdoctor"ed.
Apr 17, 2019
I was able to get rid of those warning but when I re-import the netlist, there is no error found but the fiducial was not in. I am wondering why because the parts is created same with lesson.
Apr 17 2019 8:28 PM
Hi Robert, I was able to figure out the fix.
robertferanec , 04-18-2019, 06:31 AM
That looks like problem with "PAD_D4MMX1MM5" and "MH_D7MM4_H3MM2". Are the names correct?
Please, what was the problem?
edward , 04-18-2019, 03:38 PM
My problem is that when I import the netlist the MH, J, and fid did not came in that is why I asked the question. I am wondering what was the warning for so I delete the parts and recreate a new one. and for the MH I have to add Class in parts properties in my PCB editor and type mechanical in the box. My Allegro is 17.2 and I think that for the mechanical have type in manually in order to work. and it is working now. I am starting to place the components.
robertferanec , 04-25-2019, 05:13 AM
Thank you for letting me know.
