Parallel Camera Input with TinyRex
CKanbak , 06-07-2018, 05:52 AM
I have a TinyRex module and I want to capture 16-bit grayscale video that is coming from an FPGA. For this, a modified TinyRex baseboard lite is used where the HDMI input and associated ICs and components are replaced with a parallel connector. Is using mxc_v4l2_capture module enough for doing this, or do I need to write a custom driver for this purpose? Also, do you know how should we modify mxc_v4l2_capture?
Any help is appreciated, Thanks in advance
robertferanec , 06-13-2018, 12:33 AM
When we were adding support for the HDMI input, it was a lot of work and for some time the software didn't want to work. The original first support was added by a guy working in completely different company (we do not have our own programmers), so I do not know exactly how to do it. What you can do, have a look at differences between the original source code and compare changes for the TinyRex. I don't think he wrote a new driver, I think, he just modified existing code, but I may be wrong. Depends what kernel you are using, but this may help:
https://github.com/voipac/linux-fslc....x-mx6-tinyrexPS: OpenRex could be maybe easier to connect. I think, you can use one of the connectors as CSI Camera input. Check Page 7:
http://www.imx6rex.com/wp-content/up...Production.pdfUse our interactive
