Issue with PCIE mini port (OpenRex)
imsaditya , 06-01-2018, 06:22 AM
The wifi card for PCIe mini was not being detected even after I tried to enable the PCIe port. I followed the instructions in [
http://www.imx6rex.com/open-rex/soft...ls/#wifi_4965] website. The TeraTerm console constantly displays the error message ---
*** No rule to make target `menuconfig'.  Stop.
And while executing the command
lspci no PCIe devices were recognized as such.
Kindly suggest how to enable the PCIe port for a wireless module and wifi module to be operated.
P.S. The kernel I'm using is Jasbir's filesystem image and it doesn't have the required drivers. Kindly tell a solution for that too.
With regards.
robertferanec , 06-01-2018, 07:15 PM
This looks to me more like problem with setup on host machine where you compile kernel. Maybe PCIE was not correctly enabled in kernel?
imsaditya , 06-03-2018, 10:08 AM
Any solution as to how we can enable PCIe in the kernel?  I'm using the Jasbir's filesystem and have updated the distribution...
robertferanec , 06-03-2018, 11:14 AM
Can you describe how did you enable the PCIe in kernel? How did you run menuconfig? You may need to run this whole command:
make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- menuconfig
It looks like, when you run menuconfig, yours setup doesn't know the TARGET.. Did you run something like this before going into menuconfig?
make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_defconfig
Here you can find more info:
http://www.imx6rex.com/software/how-...el_compilationUse our interactive
