Position Virtualization using Openrex & Blender Software
imsaditya , 05-31-2018, 07:11 AM
Upon executing the blender embedded game, the blender terminal window shows an error showing, UNABLE TO ACCESS COM PORT....ACCESS IS DENIED. (COM8)
I have already compiled the main.c file in openrex and successfully run the application from TeraTerm terminal. But the blender is unable to access com port although I have specified the same COM port as TeraTerm and same baud rate as 115200.
Pls help asap.
P.S. I also tried running blender as Admin and also changed the COM ports but same results every time.
robertferanec , 05-31-2018, 08:06 PM
Did you try to close the terminal window? Maybe the COM port is used by some other application - that is usual reason why Blender can not open the port.
