setenv machid 12a9Hello Mr. Feranec and community,
I am evaluating a prototype board that is based on the iMX6 Rex module core design, with a Quad processor. I would like to get the Android 7.1 image provided on Voipac booting on this board from SATA, as we do not have working SD slot on this prototype (an oversight which will be corrected next time around). Goal is to see if I can drive an LVDS display with Android.
Problem:
I have been trying to follow a combination of both write-ups below, though I am tripping because of a couple reasons. For context, I am starting on u-boot-imx6-rexpro-2.4.imx, which I have put on SPI flash and my board is fused to boot from the SPI flash (similar setup as the shipped module)
http://www.imx6rex.com/software/how-...d-on-imx6-rex/http://wiki.voipac.com/xwiki/bin/vie...+rex/android711) I wonder if the script vpac-sdcard-partition.sh on Voipac can correctly create the partitions on a SATA SSD as opposed to an SD card. For me, it creates 7 partitions when I use an SD card, and 12 partitions when I do it on a SATA drive. There are no apparent problems in the process, however I can't be sure until I can successfully boot off the SSD.
2) In the part where you do the following....
mw.l 0x020d8040 0x3040; mw.l 0x020d8044 0x10000000; reset
setenv machid 12a9
setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1280x720M@60,if=RGB666 video=mxcfb1
![Embarrassment](https://designhelp.fedevel.com/core/images/smilies/redface.png)
ff video=mxcfb2
ff fbmem=28M vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
booti mmc1
What is the mw.l step then reset doing? Second, "booti" does not appear to be an included command in the uBoot. I assume it is supposed to reset and boot from the MMC1 device, though in my case I would want to do Sata 0. In any case though, booti does not seem to be included in u-boot-imx6-rexpro-2.4.imx?
I appreciate any help and insights! Thank you!
-Tony |
