setenv bootargs_mmc 'setenv bootargs ${bootargs} ip=dhcp root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB666 vmalloc=400M fbmem=28M fbcon=28M'setenv bootcmd_mmc 'run bootargs_mmc ; mmc dev 1; ext2load mmc 1 0x10800000 uImage-gpu 3916636; bootm 0x10800000'
U-Boot 2015.04-g9de6034 (Dec 13 2016 - 06:48:43)CPU: Freescale i.MX6Q rev1.2 at 792 MHzCPU: Temperature 23 CReset cause: PORBoard: MX6 Rex - proI2C: readyDRAM: 2 GiBMMC: FSL_SDHC: 0, FSL_SDHC: 1SF: Detected SST25VF032B with page size 256 Bytes, erase size 4 KiB, total 4 MiBIn: serialOut: serialErr: serialNet: FEC [PRIME]Boot from USB for mfgtoolsUse default environment for mfgtoolsRun bootcmd_mfg: <NULL>Rex U-Boot >
Rex U-Boot > setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p2 rootwait panic=10 ${extra}Rex U-Boot > ext2load mmc 0 0x48000000 uImage4454450 bytes read in 332 ms (12.8 MiB/s)Rex U-Boot >
Rex U-Boot > bootm 0x48000000## Booting kernel from Legacy Image at 48000000 ... Image Name: 3.15.9-rex5 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4454386 Bytes = 4.2 MiB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK Loading Kernel Image ... OKNo gpc device node -9, force to ldo-enable.Starting kernel ...[ 0.000000] Booting Linux on physical CPU 0x0[ 0.000000] Initializing cgroup subsys cpuset[ 0.000000] Initializing cgroup subsys cpu[ 0.000000] Initializing cgroup subsys cpuacct[ 0.000000] Linux version 3.15.9-rex5 (root@ubuntu) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #1 SMP Wed Dec 21 23:51:40 PST 2016[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache[ 0.000000] Machine model: Rex i.MX6 Quad Board[ 0.000000] cma: CMA: reserved 16 MiB at 3e800000[ 0.000000] Memory policy: Data cache writealloc[ 0.000000] PERCPU: Embedded 9 pages/cpu @ed7ac000 s14528 r8192 d14144 u36864[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768[ 0.000000] Kernel command line: console=ttymxc0,115200 console=tty0 root=/dev/mmcblk0p1 rootwait video=HDMI-A-1:1280x720@60e[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)[ 0.000000] allocated 4194304 bytes of page_cgroup[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups[ 0.000000] Memory: 2045312K/2097152K available (8535K kernel code, 582K rwdata, 3208K rodata, 534K init, 950K bss, 51840K reserved, 1318912K highmem)[ 0.000000] Virtual kernel memory layout:[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)[ 0.000000] .text : 0xc0008000 - 0xc0b7ff98 (11744 kB)[ 0.000000] .init : 0xc0b80000 - 0xc0c058c0 ( 535 kB)[ 0.000000] .data : 0xc0c06000 - 0xc0c97818 ( 583 kB)[ 0.000000] .bss : 0xc0c97818 - 0xc0d85304 ( 951 kB)[ 0.000000] Hierarchical RCU implementation.[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.[ 0.000000] NR_IRQS:16 nr_irqs:16 16[ 0.000000] L310 cache controller enabled[ 0.000000] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1024 kB[ 0.000000] Switching to timer-based delay loop[ 0.000007] sched_clock: 32 bits at 66MHz, resolution 15ns, wraps every 65075262448ns[ 0.000655] Console: colour dummy device 80x30[ 0.000983] console [tty0] enabled[ 0.001003] Calibrating delay loop (skipped), value calculated using timer frequency.. 132.00 BogoMIPS (lpj=660000)[ 0.001028] pid_max: default: 32768 minimum: 301[ 0.001133] Security Framework initialized[ 0.001168] AppArmor: AppArmor disabled by boot time parameter[ 0.001182] Yama: becoming mindful.[ 0.001350] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)[ 0.001370] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)[ 0.001999] Initializing cgroup subsys memory[ 0.002029] Initializing cgroup subsys devices[ 0.002048] Initializing cgroup subsys freezer[ 0.002063] Initializing cgroup subsys net_cls[ 0.002078] Initializing cgroup subsys blkio[ 0.002092] Initializing cgroup subsys perf_event[ 0.002141] CPU: Testing write buffer coherency: ok[ 0.002426] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000[ 0.002497] Setting up static identity map for 0x1081f8e8 - 0x1081f940[ 0.006539] CPU1: Booted secondary processor[ 0.006565] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001[ 0.007587] CPU2: Booted secondary processor[ 0.007608] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002[ 0.008608] CPU3: Booted secondary processor[ 0.008628] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003[ 0.008745] Brought up 4 CPUs[ 0.008824] SMP: Total of 4 processors activated.[ 0.008839] CPU: All CPU(s) started in SVC mode.[ 0.009484] devtmpfs: initialized[ 0.013440] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4[ 0.015193] xor: measuring software checksum speed[ 0.110126] arm4regs : 1212.000 MB/sec[ 0.210123] 8regs : 776.400 MB/sec[ 0.310123] 32regs : 763.600 MB/sec[ 0.410122] neon : 827.600 MB/sec[ 0.410138] xor: using function: arm4regs (1212.000 MB/sec)[ 0.410161] pinctrl core: initialized pinctrl subsystem[ 0.410511] regulator-dummy: no parameters[ 0.417961] NET: Registered protocol family 16[ 0.420680] DMA: preallocated 256 KiB pool for atomic coherent allocations[ 0.421389] cpuidle: using governor ladder[ 0.421406] cpuidle: using governor menu[ 0.421498] CPU identified as i.MX6Q, silicon rev 1.2[ 0.429081] vdd1p1: 800 <--> 1375 mV at 1100 mV [ 0.429463] vdd3p0: 2800 <--> 3150 mV at 3000 mV [ 0.429836] vdd2p5: 2000 <--> 2750 mV at 2400 mV [ 0.430231] vddarm: 725 <--> 1450 mV at 1150 mV [ 0.430642] vddpu: 725 <--> 1450 mV [ 0.431030] vddsoc: 725 <--> 1450 mV at 1175 mV [ 0.438133] No ATAGs?[ 0.438166] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.[ 0.438191] hw-breakpoint: maximum watchpoint size is 4 bytes.[ 0.439108] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver[ 0.610501] raid6: int32x1 116 MB/s[ 0.780226] raid6: int32x2 155 MB/s[ 0.950424] raid6: int32x4 168 MB/s[ 1.120267] raid6: int32x8 190 MB/s[ 1.290119] raid6: neonx1 592 MB/s[ 1.460205] raid6: neonx2 638 MB/s[ 1.630124] raid6: neonx4 634 MB/s[ 1.800171] raid6: neonx8 501 MB/s[ 1.800186] raid6: using algorithm neonx2 (638 MB/s)[ 1.800201] raid6: using intx1 recovery algorithm[ 1.802334] mxs-dma 110000.dma-apbh: initialized[ 1.802934] 3P3V: 3300 mV [ 1.803273] usbh1_vbus: 5000 mV [ 1.803616] usb_otg_vbus: 5000 mV [ 1.804550] SCSI subsystem initialized[ 1.805026] usbcore: registered new interface driver usbfs[ 1.805103] usbcore: registered new interface driver hub[ 1.805237] usbcore: registered new device driver usb[ 1.806568] i2c i2c-0: IMX I2C adapter registered[ 1.807248] i2c i2c-1: IMX I2C adapter registered[ 1.807528] i2c i2c-2: IMX I2C adapter registered[ 1.807650] Linux video capture interface: v2.00[ 1.807733] pps_core: LinuxPPS API ver. 1 registered[ 1.807751] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>[ 1.807787] PTP clock support registered[ 1.808007] Advanced Linux Sound Architecture Driver Initialized.[ 1.809321] cfg80211: Calling CRDA to update world regulatory domain[ 1.809407] NetLabel: Initializing[ 1.809421] NetLabel: domain hash size = 128[ 1.809434] NetLabel: protocols = UNLABELED CIPSOv4[ 1.809498] NetLabel: unlabeled traffic allowed by default[ 1.809890] Switched to clocksource mxc_timer1[ 1.869167] NET: Registered protocol family 2[ 1.869859] TCP established hash table entries: 8192 (order: 3, 32768 bytes)[ 1.870008] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)[ 1.870164] TCP: Hash tables configured (established 8192 bind 8192)[ 1.870326] TCP: reno registered[ 1.870349] UDP hash table entries: 512 (order: 2, 16384 bytes)[ 1.870403] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)[ 1.870702] NET: Registered protocol family 1[ 1.871143] RPC: Registered named UNIX socket transport module.[ 1.871163] RPC: Registered udp transport module.[ 1.871175] RPC: Registered tcp transport module.[ 1.871188] RPC: Registered tcp NFSv4.1 backchannel transport module.[ 1.871655] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available[ 1.873256] futex hash table entries: 1024 (order: 4, 65536 bytes)[ 1.873380] audit: initializing netlink subsys (disabled)[ 1.873427] audit: type=2000 audit(1.859:1): initialized[ 2.065572] bounce pool size: 64 pages[ 2.065879] VFS: Disk quotas dquot_6.5.2[ 2.065950] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)[ 2.066567] NFS: Registering the id_resolver key type[ 2.066615] Key type id_resolver registered[ 2.066631] Key type id_legacy registered[ 2.066655] nfs4filelayout_init: NFSv4 File Layout Driver Registering...[ 2.066895] fuse init (API version 7.23)[ 2.067111] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled[ 2.067848] msgmni has been set to 1450[ 2.069053] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)[ 2.069224] io scheduler noop registered[ 2.069242] io scheduler deadline registered[ 2.069296] io scheduler cfq registered (default)[ 2.069759] imx-weim 21b8000.weim: Driver registered.[ 2.075361] imx-sdma 20ec000.sdma: initialized[ 2.075903] imx-sdma 20ec000.sdma: firmware not found[ 2.076100] Serial: IMX driver[ 2.076421] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX[ 2.904720] console [ttymxc0] enabled[ 2.909139] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX[ 2.918522] [drm] Initialized drm 1.1.0 20060810[ 2.923708] at24 1-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write[ 2.934335] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled[ 2.941368] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode[ 2.950205] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst [ 2.960911] scsi0 : ahci_platform[ 2.964613] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71[ 2.974680] spi_imx 200c000.ecspi: probed[ 2.979865] m25p80 spi2.0: sst25vf032b (4096 Kbytes)[ 2.985969] spi_imx 2010000.ecspi: probed[ 2.991137] 2188000.ethernet supply phy not found, using dummy regulator[ 3.013659] libphy: fec_enet_mii_bus: probed[ 3.018502] fec 2188000.ethernet eth0: registered PHC device 0[ 3.024868] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver[ 3.031449] ehci-mxc: Freescale On-Chip EHCI Host driver[ 3.036941] usbcore: registered new interface driver usb-storage[ 3.043841] imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_GPIO_1 already requested by 2.regulator; cannot claim for 2184000.usb[ 3.055121] imx6q-pinctrl 20e0000.iomuxc: pin-137 (2184000.usb) status -22[ 3.062041] imx6q-pinctrl 20e0000.iomuxc: could not request pin 137 (MX6Q_PAD_GPIO_1) from group usbotggrp on device 20e0000.iomuxc[ 3.073989] imx_usb 2184000.usb: Error applying setting, reverse things back[ 3.084427] imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_EIM_D31 already requested by 1.regulator; cannot claim for 2184200.usb[ 3.095782] imx6q-pinctrl 20e0000.iomuxc: pin-52 (2184200.usb) status -22[ 3.102611] imx6q-pinctrl 20e0000.iomuxc: could not request pin 52 (MX6Q_PAD_EIM_D31) from group usbh1grp on device 20e0000.iomuxc[ 3.114471] imx_usb 2184200.usb: Error applying setting, reverse things back[ 3.122806] ci_hdrc ci_hdrc.1: doesn't support gadget[ 3.127887] ci_hdrc ci_hdrc.1: EHCI Host Controller[ 3.132821] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1[ 3.159916] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00[ 3.165591] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002[ 3.172425] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 3.179670] usb usb1: Product: EHCI Host Controller[ 3.184577] usb usb1: Manufacturer: Linux 3.15.9-rex5 ehci_hcd[ 3.190441] usb usb1: SerialNumber: ci_hdrc.1[ 3.195521] hub 1-0:1.0: USB hub found[ 3.199335] hub 1-0:1.0: 1 port detected[ 3.204075] mousedev: PS/2 mouse device common for all mice[ 3.210219] i2c /dev entries driver[ 3.214450] IR NEC protocol handler initialized[ 3.219000] IR RC5(x) protocol handler initialized[ 3.223831] IR RC6 protocol handler initialized[ 3.228376] IR JVC protocol handler initialized[ 3.232939] IR Sony protocol handler initialized[ 3.237571] IR RC5 (streamzap) protocol handler initialized[ 3.243168] IR SANYO protocol handler initialized[ 3.247885] IR Sharp protocol handler initialized[ 3.252618] IR MCE Keyboard/mouse protocol handler initialized[ 3.260034] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)[ 3.268527] sdhci: Secure Digital Host Controller Interface driver[ 3.274745] sdhci: Copyright(c) Pierre Ossman[ 3.279117] sdhci-pltfm: SDHCI platform and OF driver helper[ 3.285593] sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed state, work on normal mode[ 3.295798] mmc0: no vqmmc regulator found[ 3.299936] mmc0: no vmmc regulator found[ 3.319923] ata1: SATA link down (SStatus 0 SControl 300)[ 3.349912] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA[ 3.360822] sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed state, work on normal mode[ 3.370032] mmc1: no vqmmc regulator found[ 3.374147] mmc1: no vmmc regulator found[ 3.419910] mmc1: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA[ 3.430367] usbcore: registered new interface driver usbhid[ 3.435958] usbhid: USB HID core driver[ 3.443346] imx-ipuv3 2400000.ipu: IPUv3H probed[ 3.448501] imx-ipuv3 2800000.ipu: IPUv3H probed[ 3.456233] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).[ 3.462902] [drm] No driver support for vblank timestamp query.[ 3.471008] imx-drm display-subsystem.10: bound imx-ipuv3-crtc.0 (ops ipu_crtc_ops)[ 3.480818] imx-drm display-subsystem.10: bound imx-ipuv3-crtc.1 (ops ipu_crtc_ops)[ 3.490620] imx-drm display-subsystem.10: bound imx-ipuv3-crtc.2 (ops ipu_crtc_ops)[ 3.498412] imx-drm display-subsystem.10: bound imx-ipuv3-crtc.3 (ops ipu_crtc_ops)[ 3.507332] imx-hdmi 120000.hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1[ 3.514631] imx-drm display-subsystem.10: bound 120000.hdmi (ops hdmi_ops)[ 3.521719] [drm] forcing HDMI-A-1 connector ON[ 3.563780] mmc1: new high speed SDHC card at address 0007[ 3.564238] mmcblk0: mmc1:0007 SD16G 14.4 GiB [ 3.565714] mmcblk0: p1[ 3.579042] Console: switching to colour frame buffer device 160x45[ 3.604039] imx-drm display-subsystem.10: fb0: frame buffer device[ 3.610420] imx-drm display-subsystem.10: registered panic notifier[ 3.616774] [drm] Initialized imx-drm 1.0.0 20120507 on minor 0[ 3.624654] sgtl5000 0-000a: sgtl5000 revision 0x11[ 3.646946] 0-000a: 1200 mV normal [ 3.650581] sgtl5000 0-000a: Using internal LDO instead of VDDD[ 3.671653] imx-sgtl5000 sound.13: sgtl5000 <-> 2028000.ssi mapping ok[ 3.683778] oprofile: using arm/armv7-ca9[ 3.690329] TCP: cubic registered[ 3.696041] NET: Registered protocol family 10[ 3.703704] mip6: Mobile IPv6[ 3.708985] NET: Registered protocol family 17[ 3.715782] Key type dns_resolver registered[ 3.724223] ThumbEE CPU extension supported.[ 3.730299] Registering SWP/SWPB emulation handler[ 3.737326] registered taskstats version 1[ 3.743891] Btrfs loaded[ 3.748238] usb_otg_vbus: disabling[ 3.760522] ALSA device list:[ 3.765211] #0: imx6-rex-sgtl5000[ 3.771823] EXT4-fs (mmcblk0p1): mounting ext3 file system using the ext4 subsystem[ 3.792268] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)[ 3.802201] VFS: Mounted root (ext3 filesystem) readonly on device 179:1.[ 3.819761] devtmpfs: mounted[ 3.825377] Freeing unused kernel memory: 532K (c0b80000 - c0c05000)[ 4.248948] random: init urandom read with 28 bits of entropy available[ 4.419288] init: plymouth-upstart-bridge main process (88) terminated with status 1[ 4.429377] init: plymouth-upstart-bridge main process ended, respawning[ 4.472411] init: plymouth-upstart-bridge main process (98) terminated with status 1[ 4.482172] init: plymouth-upstart-bridge main process ended, respawning[ 4.515010] init: plymouth-upstart-bridge main process (102) terminated with status 1[ 4.525029] init: plymouth-upstart-bridge main process ended, respawning[ 4.551438] init: plymouth-upstart-bridge main process (105) terminated with status 1[ 4.561375] init: plymouth-upstart-bridge main process ended, respawning[ 4.600995] init: ureadahead main process (91) terminated with status 5 * Starting Mount filesystems on boot [ OK ] * Starting Populate /dev filesystem [ OK ] * Stopping Populate /dev filesystem [ OK ] * Starting Populate and link to /run filesystem [ OK ] * Stopping Populate and link to /run filesystem [ OK ] * Stopping Track if upstart is running in a container [ OK ] * Starting Initialize or finalize resolvconf [ OK ] * Starting Signal sysvinit that virtual filesystems are mounted [ OK ] * Starting Signal sysvinit that virtual filesystems are mounted [ OK ] * Starting Bridge udev events into upstart [ OK ] * Starting Signal sysvinit that remote filesystems are mounted [ OK ] * Starting device node and kernel event manager [ OK ] * Starting load modules from /etc/modules [ OK ] * Starting cold plug devices [ OK ] * Starting log initial device creation [ OK ] * Stopping load modules from /etc/modules [ OK ] * Starting set console font [ OK ] * Stopping set console font [ OK ] * Starting userspace bootsplash [ OK ] * Stopping userspace bootsplash [ OK ] * Starting Send an event to indicate plymouth is up [ OK ] * Stopping Send an event to indicate plymouth is up [ OK ] * Stopping cold plug devices [ OK ] * Stopping log initial device creation [ OK ] * Starting configure network device security [ OK ] * Starting Mount network filesystems [ OK ] * Starting configure network device security [ OK ] * Stopping Mount network filesystems [ OK ] * Starting configure network device [ OK ] * Starting Bridge socket events into upstart [ OK ]The disk drive for / is not ready yet or not present.keys:Continue to wait, or Press S to skip mounting or M for manual recovery
* Starting Signal sysvinit that local filesystems are mounted [ OK ] * Starting configure network device security [ OK ] * Stopping Mount filesystems on boot [ OK ] * Starting Failsafe Boot Delay [ OK ] * Starting flush early job output to logs [ OK ] * Starting configure virtual network devices [ OK ] * Starting flush early job output to logs [fail] * Starting Bridge file events into upstart [ OK ] * Starting system logging daemon [ OK ] * Starting Mount network filesystems [ OK ] * Starting configure network device [ OK ] * Stopping Failsafe Boot Delay [ OK ] * Starting System V initialisation compatibility [ OK ] * Stopping System V initialisation compatibility [ OK ] * Stopping Mount network filesystems [ OK ] * Starting System V runlevel compatibility [ OK ] * Starting regular background program processing daemon [ OK ] * Starting save kernel messages [ OK ] * Starting save kernel messages [fail] * Stopping System V runlevel compatibility [ OK ] * Starting OpenSSH server [ OK ]
Starting Mount filesystems on boot [fail] * Starting set console keymap [ OK ]
console=ttymxc0,115200 console=tty0 root=/dev/mmcblk0p1 rootwait rw video=HDMI-A-1:1280x720@60e
sudo ./build_kernel.sh
[COLOR=#373737][FONT="][SIZE=15px]2. Because the new kernel cannot pass the parameters set in u-boot they need to be compiled directly into the kernel. Open defconfig file:...[/SIZE][/FONT][/COLOR] [COLOR=#373737][FONT="][SIZE=15px]Look for [/SIZE][/FONT][/COLOR][I]CONFIG_CMDLINE[/I][COLOR=#373737][FONT="][SIZE=15px] parameter. If you for example want to boot from hard drive you will change it to:...[/SIZE][/FONT][/COLOR]
CONFIG_CMDLINE="console=ttymxc0,115200 console=tty0 root=/dev/mmcblk0p1 rootwait video=HDMI-A-1:1280x720@60e"[COLOR=#373737][FONT="][SIZE=15px][/SIZE][/FONT][/COLOR]
/* Env settings */#define CONFIG_ENV_CONSOLE_DEV "ttymxc0"#define CONFIG_ENV_MMCROOT "/dev/mmcblk2p2"#define CONFIG_ENV_DEFAULT_UBT_FILE "u-boot-" CONFIG_REX_DEFAULT_ARCH_PREFIX "-rex" CONFIG_REX_DEFAULT_ARCH_POSTFIX ".imx"#define CONFIG_ENV_DEFAULT_IMG_FILE "zImage-" CONFIG_REX_DEFAULT_ARCH_PREFIX "-rex" CONFIG_REX_DEFAULT_ARCH_POSTFIX#define CONFIG_ENV_DEFAULT_FDT_FILE CONFIG_REX_DEFAULT_ARCH_PREFIX "-rex" CONFIG_REX_DEFAULT_ARCH_POSTFIX ".dtb"#define CONFIG_ENV_DEFAULT_SCR_FILE "boot-" CONFIG_REX_DEFAULT_ARCH_PREFIX "-rex" CONFIG_REX_DEFAULT_ARCH_POSTFIX ".scr"#define CONFIG_ENV_DEFAULT_ETH_ADDR "00:0D:15:00:D1:75"#define CONFIG_ENV_DEFAULT_CLIENT_IP "192.168.0.150"#define CONFIG_ENV_DEFAULT_SERVER_IP "192.168.0.1"#define CONFIG_ENV_DEFAULT_NETMASK "255.255.255.0"#define CONFIG_ENV_DEFAULT_TFTP_DIR "imx6"#ifdef CONFIG_SYS_MMC_ENV_DEV#define CONFIG_ENV_MMC_ENV_DEV __stringify(CONFIG_SYS_MMC_ENV_DEV)#else#define CONFIG_ENV_MMC_ENV_DEV __stringify(0)#endif
baudrate=115200boot_fdt=trybootargs=console=ttymxc0,115200 console=tty0 root=/dev/mmcblk0p1 rootwait video=HDMI-A-1:1280x720@60ebootcmd=mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fibootdelay=1bootscript=echo Running bootscript from mmc ...; sourceconsole=ttymxc0ethprime=FECfdt_addr=0x18000000fdt_file=imx6-rexpro.dtbfdt_high=0xffffffffimage=uImageinitrd_high=0xffffffffloadaddr=0x10800000loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}mmcargs=setenv bootargs console=${console},${baudrate} ${video} root=${mmcroot}mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;mmcdev=0mmcpart=1mmcroot=/dev/mmcblk0p1netargs=setenv bootargs console=${console},${baudrate} ${video} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcpnetboot=echo Booting from net ...; run set_ethernet; run netargs; tftp ${tftp_dir}/${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if tftp ${fdt_addr} ${tftp_dir}/${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;script=boot-imx6-rexpro.scrset_ethernet=if test -n ${ethaddr}; then; else setenv ethaddr XX:XX:XX:XX:XX:XX; fi; if test -n ${ipaddr}; then; else setenv ipaddr 192.168.0.150; fi; if test -n ${serverip}; then; else setenv serverip 192.168.0.1; fi; if test -n ${netmask}; then; else setenv netmask 255.255.255.0; fispics=2spidev=2tftp_dir=imx6uboot=u-boot-imx6-rexpro.imxupdate_fdt=run set_ethernet; run update_set_filename; if mmc dev ${mmcdev}; then if tftp ${tftp_dir}/${upd_fdt}; then fatwrite mmc ${mmcdev}:${mmcpart} ${loadaddr} ${fdt_file} ${filesize}; fi; fiupdate_kernel=run set_ethernet; run update_set_filename; if mmc dev ${mmcdev}; then if tftp ${tftp_dir}/${upd_kernel}; then fatwrite mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} ${filesize}; fi; fiupdate_script=run set_ethernet; run update_set_filename; if mmc dev ${mmcdev}; then if tftp ${tftp_dir}/${upd_script}; then fatwrite mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script} ${filesize}; fi; fiupdate_set_filename=if test -n ${upd_uboot}; then; else setenv upd_uboot u-boot-imx6-rexpro.imx; fi; if test -n ${upd_kernel}; then; else setenv upd_kernel zImage-imx6-rexpro; fi; if test -n ${upd_fdt}; then; else setenv upd_fdt imx6-rexpro.dtb; fi; if test -n ${upd_script}; then; else setenv upd_script boot-imx6-rexpro.scr; fiupdate_uboot=run set_ethernet; run update_set_filename; if sf probe ${spidev}:${spics}; then if tftp ${tftp_dir}/${upd_uboot}; then setexpr align_sz ${filesize} + 0x7FFF; setexpr align_sz ${align_sz} / 0x8000; setexpr align_sz ${align_sz} * 0x8000; sf erase 0x0 ${align_sz}; sf write ${loadaddr} 0x400 ${filesize}; fi; fi
