How to control length matching?
Khai , 08-28-2016, 08:12 PM
Hi Robert and everyone,
How's the ways you used when you layout in Layer 10(project iMX6 Rex)? I can't control length matching when I layout here, please suggest for me the ways I can use to control the length.
Thanks.
robertferanec , 08-30-2016, 05:00 PM
It's combination of several techniques.
- On the beginning, we draw and do length matching of the last (smallest) segments for two memory chips above each other. Then we copy and place it to the other one.
- After that, we draw preliminary connections (connect all the ADDR/CMD/CTL pins). Try to place the VIAs which are between the two memory chips into middle between them (so the branches between the memory chips are similar).
- Then do preliminary length matching of the branches between the memories (that is the most time consuming part).
- Once it is done, you have more options to length match the longest part of the track. You can use for example xSignals or you can do something what I call "temporarily remove part of layout" (move away from your PCB part of layout - only leave tracks between CPU and ONE memory chip, do the length matching, move the tracks back).
You may watch some of the videos I have done.
Khai, 08-31-2016, 06:44 AM
Thanks Robert, I thought I need time to practice )
