U-boot, Linux and Yocto course cant compile for: iMX8M Industrial Development Kit
ssv102 , 12-07-2022, 03:37 PM
My team is taking the U-boot, Linux and Yocto course using the iMX8M Industrial Development Kit. They have not been able to get Yocto to compile without issues. We are currently running Ubuntu 14.04 per the recommendation.
We choose the above board because its the board recommended in the class description.
The current error is as follows:
ux/libnsl2-native/1.2.0+gitAUTOINC+4a062cf418-r0/recipe-sysroot-native/usr/include -O2 -pipe -c ../../git/src/yp_master.c -fPIC -DPIC -o .libs/yp_master.o
| In file included from ../../git/src/ypprot_err.c:22:
| ../../git/src/rpcsvc/yp_prot.h:10:10: fatal error: rpc/rpc.h: No such file or directory
| 10 | #include <rpc/rpc.h>
| compilation terminated.
| ../../git/src/yp_xdr.c:38:10: fatal error: netconfig.h: No such file or directory
| 38 | #include <netconfig.h>
| make[2]: *** [Makefile:586: ypprot_err.lo] Error 1
| make[2]: *** Waiting for unfinished jobs....
| make[2]: *** [Makefile:586: yp_xdr.lo] Error 1
| ../../git/src/yp_master.c:21:10: fatal error: rpc/clnt.h: No such file or directory
| 21 | #include <rpc/clnt.h>
| make[2]: *** [Makefile:586: yp_master.lo] Error 1
| In file included from ../../git/src/do_ypcall.c:28:
| make[2]: *** [Makefile:586: do_ypcall.lo] Error 1
| make[2]: Leaving directory '/home/shane/dev/yocto-classes/build-voipac/tmp/work/x86_64-linux/libnsl2-native/1.2.0+gitAUTOINC+4a062cf418-r0/build/src'
| make[1]: *** [Makefile:482: all-recursive] Error 1
| make[1]: Leaving directory '/home/shane/dev/yocto-classes/build-voipac/tmp/work/x86_64-linux/libnsl2-native/1.2.0+gitAUTOINC+4a062cf418-r0/build'
| make: *** [Makefile:391: all] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Execution of '/home/shane/dev/yocto-classes/build-voipac/tmp/work/x86_64-linux/libnsl2-native/1.2.0+gitAUTOINC+4a062cf418-r0/temp/run.do_compile.2790' failed with exit code 1
ERROR: Task (virtual:native:/home/shane/dev/yocto-classes/sources/poky/meta/recipes-extended/libnsl/libnsl2_git.bb:do_compile) failed with exit code '1'
marekb , 12-08-2022, 04:20 AM
ssv102, 12-08-2022, 08:02 AM
Fedevel should fix their link on their course page then because when you click on it it takes you to the  iMX8M Industrial Development Kit site which is why I ordered those boards.https://github.com/voipac/yocto-imx8m-voipac is the layer that we have been using but it does not compile.Is there a board (which is in stock) that you do recommend for your course?
marekb , 12-08-2022, 01:32 PM
yocto-imx8m-voipac layer was verified to be build on Ubuntu 18.04 and ubuntu 20.04. Which OS do you use for building please?  Thanks.
robertferanec , 12-12-2022, 05:59 AM
@ssv102 I checked the link. VOIPAC has a new website and iMX6 link now goes to their home page. As mentioned in the course description, the board used in the YOCTO course is called OpenRex MAX, here is a link to their new website:
https://www.voipac.com/imx6-openrex-development-kit-maxI apologize and thank you for pointing this out.
