Issue with Connecting Nets Across Schematic Pages – Duplicate Net Name Error
Al , 03-03-2025, 05:11 PM
Hi all,I am currently working on a schematic for an Advanced Digital Hardware Design course by Philip Salmony and have encountered an issue when trying to connect nets across different pages of my schematic.Specifically, I am trying to connect signals like DDR_CKE from one page to another, but I am getting errors related to duplicate net names for Wire_CKE. My design is flat, and I am unsure how to correctly connect these nets without causing conflicts.Has anyone encountered a similar issue before? What is the correct way to connect nets across multiple pages in a flat design? Any guidance or best practices would be greatly appreciated!Thanks in advance!
Denis , 03-03-2025, 05:21 PM
Hi Al,I'm working on the scheme as well. I'm drawing it in the KiCad.Not sure if it help with Altium (I dont have any practice with it).I used Global Label for nets that need to use in different sheets.Otherwise labels are visible only on one sheet.
Al , 03-03-2025, 05:26 PM
The netnames connect to sheets in Kicad diffrent compared to Altium. In Altium I have to use ports and off sheet connectors , but there is a better way to do it in Altium which I am not sure off.  I looked at Roberts old schematics that I did for another training where he created schematic components where he defined each pin of the components as passive. I am using components where the pins are defined as either output, input or bi-directional.
Denis , 03-03-2025, 05:38 PM
Can you try to connect CKE signal in the same way as CLK_P and CLK_N?If they dont have issue with net duplicate
Al , 03-03-2025, 06:08 PM
I have used a port with a net name like you suggested , and connect to DDR_CKE port on the other page to see if I get an error. So far the error has gone after I validated the project in Altium. If you see my page 11 ,  breaking the wire and adding nets to join them gets messy.  The schematic does become neat like I wanted to in  Philip Salmony schematic.
QDrives , 03-03-2025, 07:25 PM
In "Flat", if you want to connect signals from one sheet to another you have to use ports. Like you already have a lot of them.
Al , 03-03-2025, 09:40 PM
@Qdrivers, I have all my schematics as flat and not Hierarchical. I made changes to the Net Identifier scope as per your recommendations, but I am getting duplicate net names bus error. How do I correct them?
QDrives , 03-03-2025, 09:41 PM
You do not have to use the same settings as I do. It was merely to show where some settings are that play a role.
QDrives , 03-03-2025, 09:44 PM
And it is not the "schematic" that is flat, but your project.
QDrives , 03-03-2025, 09:46 PM
What is you get rid of one of the duplicate ports?
Only have one port (with the same name) on a sheet.
Al , 03-03-2025, 09:49 PM
Oh, I see makes sense. I did not know about only one port (with the same name) on a sheet. Should I change the Net Identifier Scope under Project options to Flat (Only ports global) or  Gllobal (Netlabels and ports global)?
Al , 03-03-2025, 09:50 PM
I changed to Global (Netlables and ports global) and many of my duplicate Net name errors are gone.
QDrives , 03-03-2025, 09:56 PM
It depends on how you want to design -- and a personal preference.
