Polygon Pour for Un-Routed net
Satyaveer Singh Rawat , 04-20-2024, 07:24 PM
Dear all please refer to the attached screenshot of my PCB, I am unable to find the path for the Un-Routed net. Please help.
Robert Feranec , 04-21-2024, 05:45 AM
use CRTL+Left click on the pad at the location where the problem is and double check how it is connected
Satyaveer Singh Rawat , 04-21-2024, 10:28 AM
@Robert Feranec Sir my question is that Q2 and Q7 are MOSFETS whose drain needs to be connected through polygon pour because it is carrying around 20 A current but situation here, now arise that another polygon PV_GND is intersecting it and because of which Q2 drain i.e. top pin is disconnected from Q7 drain. I can't remove the PV_GND polygon also because it has to connect with Q6 source i.e. middle two pins. flip side is also blocked by other polygons as shown in attached screenshot. Is their any other way-out to resolve the problem?
QDrives , 04-21-2024, 10:02 PM
You can change the order of the polygons in the polygon manager.
