PCB panel board fabrication output files have a problem
, 09-28-2024, 06:57 PM
hello guys , i have a problem with my panelized board , when i use embedded board array tool and make my panel and create route tool path and and slice tracks and do the mouse bites all is fine from altium 3d viewer , when i generate gerber file and NC drill file there is a problem that when i define the route tool path option from NC drill file it remove the sliced tracks and the mouse bites and the board is not connected any more with the panel i will appreciate any one know the solution or face this problem before and solve it thank you all
QDrives , 09-29-2024, 01:45 PM
Did you add the "root tool path" layer in your Gerber export?I do not know in which layers you added things. I place the mouse bites in multilayer.
, 09-29-2024, 03:23 PM
yes i do this as i mentioned the gerber file is ok but the problem is with NC drill file can you show it to me please?
QDrives , 09-29-2024, 08:41 PM
I got the mouse bites in the NC drill and route tool path in Gerber X2.The mouse bites are NPTH pads in my case.The route tool path and V-cuts are just additional layers in the gerber files.
