I am currently working on a motor driver circuit. using H-bridge topology. and I am using a gate driver ic(ir2103) for controlling the mosfet. but the thing is am applying 5v supply to the logic input but not getting any output. there is a typical schematic mentioned at the datasheet of the IC. but no clear value or any BOM is given there. I follow @Phil youtube channel. this IC is used in there for an ESC circuit. so I used that schematic as a reference for this IC. Is there anybody who used this IC or have any experienced with it, I would really appreciate if anybody can help.
FuzzyOtter , 09-11-2025, 02:21 PM
Show us the exact schematic, don't just show us some random snippet. Explain, exactly, what troubleshooting you've done.
Abrar , 09-11-2025, 02:25 PM
this is the schematics.
Abrar , 09-11-2025, 02:29 PM
I supplies 5v to H-1(net) and L-2(net) to get 24v output from the mosfets
QDrives , 09-11-2025, 07:58 PM
Did you check this comment:But check figure 1 on page 8 of this datasheet https://www.infineon.com/assets/row/public/documents/60/49/infineon-ir2103-datasheet-en.pdf to see where your thinking goes wrong (hint).
Abrar , 09-11-2025, 08:29 PM
I did. but the problem was. Q3 and Q4 mosfet were turning on. I mean the low side mosfets are working but only the high side were not
QDrives , 09-11-2025, 08:35 PM
Q1 should turn on when both H_1 and L_1 are high.
Abrar , 09-12-2025, 05:00 AM
are you refering to this?
Abrar , 09-12-2025, 05:01 AM
does that mean when both H_1 and L_1 are low, Q3 should turn on?
QDrives , 09-12-2025, 01:51 PM
Yes. A table would have been better.So, both inputs high -> high side output on.Both inputs low -> low side output on.The other two cases -> both outputs off.
Abrar , 09-12-2025, 02:38 PM
In this case, if i don't give any supply to both inputs, then the low side output will always be on.Correct me if I'm wrong
FuzzyOtter , 09-12-2025, 02:44 PM
It sounds like you don't understand what that silly little line over "L IN" means
It means that input is active low
QDrives , 09-12-2025, 11:05 PM
HIN has an internal pull-down and /LIN has an internal pull-up.If you do not connect anything, both outputs will be off.
Abrar , 09-22-2025, 06:28 AM
Is it possible to just use 5v logic to control, or PWM signal is mandatory? because 100% duty cycle = 5v
QDrives , 09-22-2025, 12:27 PM
The shown gate drivers use simple a bootstrap circuit, so no, you cannot do 100% high side on.For the low side you can.
