merge two different gnd from a single point (net tie) issue
blackbird , 12-15-2024, 03:55 PM
I am having problems when I want to merge two different gnd from a single point with net tie and polygoun pouring.I want to combine them into one piece. Any help?I can place a solid region, but I want to have a clean project that will create a violation in healt check.
QDrives , 12-15-2024, 04:42 PM
I do not understand your question.
"Merge" and "Net tie" are contradicting each other.
Looking at the layout I can only imagine that the issue is the clearance that the polygons apply to the trace in the net tie.
Also, I guess you want to remove the paste mask and solder mask from the pads as they are not for a component, but functional for routing.
blackbird , 12-15-2024, 04:51 PM
hi thanks for your feedback .its not filled these points
blackbird , 12-15-2024, 04:55 PM
Yes, I removed the paste mask and solder mask as you said.
QDrives , 12-15-2024, 05:08 PM
You might be able to create a special net-tie clearance rules that sets the clearance to the footprint to 0.
I have not tried something you have, all the ones I did were more like a trace.
Do you actually need to split the Gnds?
blackbird , 12-15-2024, 05:16 PM
yes, pcb has already passed emc and has fcc-ce documents , this is a remake .ti also suggests the same layout.so have no worries about separating the gnds
blackbird , 12-15-2024, 05:18 PM
Even if I change the clearance, the gaps continue to remain.
QDrives , 12-15-2024, 08:00 PM
It seems to be a 'bug' in the clearance calculation for the polygons.
If I use traces or fills, it will put copper there without errors.
QDrives , 12-15-2024, 08:01 PM
One other comment: you have 0402 resistors with a thermal inbalance. Chances are high that you get tombstoning there. Better add some thermal relief on the pads.
