LEM current sensor connection
Satyaveer Singh Rawat , 04-02-2024, 06:40 PM
In attached Screenshot I want at connect +15V and -15V of 3P Detachable PC to +15 and -15 of LEM LA-55P/100P. Can I do it as shown here i.e. just giving +15 and -15 net level from 3P Detachable PC .
Mini , 04-02-2024, 06:44 PM
I don't understund your question. For power you can use power port like you have used on the bottom.
Mini , 04-02-2024, 06:46 PM
Ah i see do you mean if you name net and power port with the same name do they connect together? Yes they do. You can always check that in the layout if you hesitate.
QDrives , 04-02-2024, 07:20 PM
I think you made a mistake wait TS2, but that was not your question.
LEM has a terrible datasheet, bit it looks connected OK.
Do add decoupling capacitors close to it.
And also note that you supply input (J5) does not have a filter nor protection.
