Component Clearance Constraint (Collision)
Silkarian , 09-10-2025, 07:56 AM
Dear Mr. Feranec,
I am following a tutorial that you have on YouTube (Link to Youtube Video) and I am kinda stuck at the point where we need to create a rule to avoid the collision where you place resistors on top of each other. When I try to do that (adding a Rule for these specific components) the error does not go away. What am I missing? Even if I put 0mils to the general Component Clearance constraint, it still does not clear the error. See picture below:
I also get Silk to Solder Mask errors, since the now part of the silkscreen of one component is on top of the soldermask of the other.
Link: https://www.youtube.com/watch?v=KWIzhbQaZZk&ab_channel=RobertFeranec
QDrives , 09-10-2025, 07:19 PM
You need to give a negative value to disable the rule.
Silkarian , 09-14-2025, 08:09 PM
Thanks a lot. That worked 🙂
