Robert Feranec , 08-02-2025, 09:52 AM
My advice is, before you start connecting anything to BGA, fan out all the BGA pins - means all powers, all signals, place all vias, connect all decoupling caps under BGA ... go with all the signals you will need to connect out of the BGA edge (for example 2mm away from BGA). Only after that start routing the signals outside of the BGA. If not done this way, often you will route 95% of all the BGA pins and then you will find out there is no other way to continue and you will have to re-route a lot of work. You can try to continue, but it looks like many signals are routed under the BGA - this can make layout hard and I dont normally route signals under bga unless there really is no other way.
