About trouble with Import changes from...
mulfycrowh , 08-29-2024, 07:29 AM
Hi everyone,I have a baseboard project with about 1500 components.I just want to add one parameter on each component in SchLib to get it in the Pick&Place file.I started with just one component.No issue while updating the schematics.The trouble appears while importing changes from PrjPcb on PCB.AD modifies/deletes the rooms and their names defined on the PCB.Here 2 screenshots of the PCB before the import and after showing the rooms location.Thanks for help.
QDrives , 08-29-2024, 07:32 PM
In the ECO, AD also shows rooms to be added or removed.Next time uncheck changes, or if all rooms are ok, uncheck room in ECO generation.
Robert Feranec , 08-30-2024, 06:29 AM
Just adding a picture to @QDrives answer: Project -> Project options -> ECO generation -> Remove Rooms -> Ignore Differences
mulfycrowh , 08-30-2024, 09:45 PM
Thank you both! I am going to check that!
mulfycrowh , 09-20-2024, 11:03 PM
If I set Remove Rooms to Ignore Differences, it doesn't solve the issue. After Importing changes ..., AD removes 4 rooms out of 7. Why? Thanks for help.
QDrives , 09-21-2024, 12:53 AM
There may be more than 1 setting. You would need to go through the entire list.
Robert Feranec , 09-21-2024, 07:50 AM
read the ECO (the list of changes altium shows you when importing the changes) it tells you what it is trying to do and then disable that specific action
