Exporting Test Points
Simonp , 09-27-2018, 07:26 AM
I need to export my test points for input into a cam software for location holes for cnc drilling and inserting Coda test pin's for a bed of nails.
What is the best procedure to export the test point locations for this purpose?
The test points are on the bottom layer, is there a way i can define the points i want to use and export only those?
I am fine with every other layer export.
Thanks
Simon
mairomaster , 09-28-2018, 02:40 AM
Something traditionally used in the industry for this purposer is IPC-D-356 netlist. Before exporting it you have to mark all your test points as such in the pad properties.
Simonp , 09-28-2018, 05:31 AM
Thanks i thought I would have to, however i wanted to see if there was another option. Many thanks!!!
robertferanec , 10-01-2018, 01:12 AM
If your testpoints are standard components, you may be able to use filter like this: "Name Like 'TP*' and IsPad". Then in properties panel mark these pads as testpoints:
Then, in job file, in Fabrication Outputs -> Test Point Report you can generate something like this:
