How can I import finished schematic and PCB design into schematic and PCB template
flyforward , 08-06-2018, 04:28 PM
I have a schematic and PCB design finished but I did not use any templates when designing them. I just wanted to know whether there is a way that I can simple import the schematic and PCB into a template schematic and PCB without redo it. Thanks in advance.
chitransh92 , 08-07-2018, 07:19 AM
Hello FlyForward,
Yes you can use the template for schematic without redoing it.
This is with Reference to Altium 18. ( They must be similar for other version also)
For schematic :
1. You may create your template as shown in this video :
https://www.youtube.com/watch?v=TYDzjcb7eRY2. Then you need to copy this saved file to : C:\Users\Public\Documents\Altium\AD18\Templates (You may check based on your version, but path will be similar)
3. Open the schematic for which you need to change the template
4. Your saved template should appear once you go to "Document option" under "template" option.
(Make sure the sheet size in the create template aligns with your original schematic sheet size)
I am unaware about the PCB template here and curious to know the same.
Thanks!
robertferanec , 08-08-2018, 08:14 AM
@chitransh92, thank you so much!
