make a module
alferdvidal , 02-05-2018, 02:43 AM
Hi guys
How can I create a module in Altium library?
I mean, what is the connection of the componets in the module?
Thank you
Alfred
robertferanec , 02-05-2018, 08:50 AM
Alfred, I am really not sure what do you mean by "module in Altium library". Could you provide more details what you are trying to achieve, possible some screenshots of examples?
alferdvidal , 02-05-2018, 10:29 AM
Hello robert
The attached document LED Strip, whose dimensions is 25 mm by 10 mm, I would like to put it in a 500 mm by 10 mm board. I would like to make this whole board as a module in the Elliott library, and then make a dimension of 500 mm in 10 mm.
am i going the right way?
I hope that I could what i meant.
thanks
Alfred
robertferanec , 02-06-2018, 10:36 AM
I am not really sure what you are trying to do. Are you trying to make a panel (500 x 10 with number of same PCBs) or you are trying to make this small PCB part of a bigger PCB with different circuits?
- To make a big panel of same PCBs, go into your PCB and have a look at Place->Embedded Board Array
- If you need to include this your board in different PCB, then you may need to include it into the project (or maybe AD18 can do it somehow, i think it had a new feature to support multiboard designs)
alferdvidal , 02-06-2018, 12:50 PM
HI Robert
Thanks for the answer, I want to repeat this board in another board several times
Regards
Alfred
robertferanec , 02-06-2018, 01:12 PM
Will be on the another board also something else or just these boards?
alferdvidal , 02-07-2018, 02:28 AM
Hi
just these board
robertferanec , 02-07-2018, 07:14 AM
Then, you may want to use the panelization feature. To make a big panel of same PCBs, go into your PCB and have a look at Place->Embedded Board Array.
alferdvidal , 02-07-2018, 12:56 PM
Dear Robert
Thank you for the help, I did it and my problem was resolved
Good luck
With respect
Alfred
