[Warning] GND contains IO Pin and Power Pin Objects
s.gesota , 11-02-2017, 07:54 AM
I have just started using Altium Designer Tool and have come across this warning :-
"GND contains IO Pin and Power Pin Objects"
I have given 'GND Power Port' to the pins that have to be grounded as per the pinouts given in the data sheet.
Can you explain what the error actually means ? I am unable to understand it and unable to debugg/ troubleshoot it.
Thanks and Regards,
Gesota S.
robertferanec , 11-02-2017, 09:08 AM
Did you set pin type in your symbols (e.g. input, output, bidirectional, etc)?
I do not assign type to symbol pins for several reasons - and this may be one of them (warnings and errors which are not very useful)
s.gesota , 11-02-2017, 10:40 PM
Thank you for replying sir.
Yes sir, the warning pops up when i have selected the pin type as INPUT.
Also there is a series Resistor which is connected to the pin.
I found some information here :-
Link 1 - Electronics Stack Exchangerobertferanec , 11-03-2017, 01:30 PM
yep, that is exactly one of the reasons why I do not set pin types - this kind of warnings.
