Clerance between vias and regions.
oscargomezf , 10-24-2017, 03:31 AM
Hi everyone,
I have a silly question. I'm doubting in leave 0.15mm or 0.2mm of clearance between region and vias.
What will be the best option and why?
Best regards,
robertferanec , 10-24-2017, 12:51 PM
Depends on board, but normally I use 0.1mm for expensive and high density boards, and I use default smallest gap for other PCBs (e.g. when I am designing a PCB with smallest clearance 0.15mm I use 0.15mm, if it is 0.2mm, I use 0.2mm). It depends what PCB price I am looking for, but generally I do not go below 0.1mm gap (unless it is unconnected pad / via on that specific layer and the ring will be removed (suppressed) during PCB manufacturing, then in some cases I may go closer).
