switching power supply error files
hemanth_s , 12-19-2016, 05:44 PM
when I am trying to draw a polygon over phase2 and pins 5,6,&7 I am getting the error. I am getting this error before I draw a polygon but its not high lighting at that instant but its highlighting once I draw the polygon and also I had a problem with net antennas they are not going off I deleted all the small leftover coppers all over the circuit but still its showing me the error. thanks Robert by the way I like the way your way of your training .
robertferanec , 12-19-2016, 06:06 PM
hemanth_s , 12-19-2016, 08:54 PM
I figured that one out, actually there is difference between new software version of Altium and the one you used it. The difference is when you double click on the window you will choose the option "pour over all the same net polygon" after you close that a small window will pop up asking for the rebuild the polgygon but this happens only in older versions software but in the newer version you have to select TOOLS->POLYGON POUR->REPOUR SELECTED.. then it works
robertferanec , 12-19-2016, 09:15 PM
Perfect! Thank you for letting me know.
Altium keeps doing changes in polygons. Some time ago I made a video about these updates, but since then they made other changes. You can have a look here:
http://www.fedevel.com/academy/updates/Use our interactive
