3-D Body not showing in PCB board
Satyaveer Singh Rawat , 05-07-2024, 09:40 AM
Dear all, Please refer to attached screenshots. I have designed Schematic and PCB board with 3-D body of all the components in PCB and schematic library. Now I have to delete 3 banana connectors from my schematic. As I have deleted that, PCB board in not showing 3-D body, while when I click the same component on schematic it is showing 3-D body in attached footprint. Also all the components in PCB library as well as schematic library is showing 3-D footprint for all the components used in my schematic/ PCB board. Please help to overcome this issue.
Robert Feranec , 05-07-2024, 02:04 PM
are the 3D bodies on the correct layer? e.g. Top 3D Body layer? did you see 3d bodies before you deleted the connectors?
Satyaveer Singh Rawat , 05-07-2024, 03:42 PM
@Robert Feranec Yes sir there was 3-D body appearing on connectors before deleting them and not only on those components it was on all the components, now it is not. 3D bodies are on top layer.
Robert Feranec , 05-07-2024, 04:02 PM
did you check the settings in the 3D View panel if 3d bodies are not disabled? Could you attach screenshot from your 3D View Configuration panel settings?
Satyaveer Singh Rawat , 05-07-2024, 05:01 PM
@Robert Feranec Attached herewith sir. Here 3-D body is visible but what I have done is that I deleted complete PCB board, added new board and again imported all the components from the same schematic and then all these components was back on PCB board with 3-D Body. This way I was able to solve the problem for time being but this happens with me earlier also that if I delete any component from schematic, again run the "update Schematic...." under Design tab, All 3-D Body gone with the deleted component. May be I can share if (unfortunately) it happens again.
QDrives , 05-07-2024, 09:07 PM
Robert means to say that the indicated switch must be correct.
Mini , 05-10-2024, 10:48 AM
I would also add that shortcut for this is "shift + Z"
QDrives , 05-10-2024, 07:56 PM
So almost the same as undo (Ctrl-Z). Hence the possible cause.
