Polygon Pour
hajri_abderaouf , 06-23-2016, 04:42 AM
i would like to know why polygon pour doesn't connect to track or solid region
is there a way to solve that ?
Thanks,
mairomaster , 06-23-2016, 05:37 AM
First the tracks/regions should have the same net as the polygon - this may be obvious but it's quite important. Second, from the polygon properties you should select Pour over all same net object. If it still doesn't work after the re-pour, check your rules - clearance rules and polygon connect style rule.
ecworks , 06-23-2016, 05:45 AM
hello friend,
you must select the net need to connect with polygon as well as select the option "Pour over all same net object".
hajri_abderaouf , 06-23-2016, 06:10 AM
Hi Friend,
thanks for your help,i solved the probleme by selecting the option "Pour over all same net object".
Regards,
