Component placement with Probe
joaorbeck , 09-01-2015, 11:33 AM
What shoud I set in Preferences to able to use the probe in schema, which will mask the PCB and then select a component on schematic without loosing the previous mask in PCB?
robertferanec , 09-01-2015, 11:49 AM
@joaorbeck I exactly know what you mean. This is a bug (or a new "future" ?) from Altium 14.3 and up.
Option 1: Temporarily you can select components first and highlight the net (CTRL + Left Click) after that. It's not as good as mask, but it helps.
Option 2: Possibly, you can use "Select" mode. Go to Schematic -> Navigator panel, move cursor on the Navigator panel -> Press right click -> and check: Select Objects.
I mentioned this problem to Altium, but I am not sure if or when they are going to fix it. I hope this helps.
robertferanec , 05-12-2016, 06:28 AM
I have created a video about this. Have a look at: Altium – Component Placement & Probing (The New & Old Way)
