Footpring manager
chris007 , 04-25-2016, 10:14 PM
I am experiencing something very weird with the footprint manager. When I allocate and validate the footprint change of some component, the footpring manager ECO , I validate and execute and everything goes fine. However later when I try to update the PCB the ECO tll me footpring is not found
When I edit manually each component one by one it works properly. I have only this problem with the footpring manager, I don't understand why it doesn't work
I attach screenshot picture in two post as there is limitation on the forum.
chris007 , 04-25-2016, 10:20 PM
mairomaster , 04-26-2016, 01:41 AM
Not quite sure what is happening without having you setup. A thing you can try is to include the particular library to you project and to make sure all the footprints link to this library. Then you shouldn't have problems.
robertferanec , 04-26-2016, 01:28 PM
Try to use "Update from library" and check if the components are using correct libraries. Have a look here >
