How to set clreance design rule between two net classes
syhaunguyen , 02-15-2016, 11:15 AM
Hi all,
I need create clearance design rule for checking in our pcb project.
I have two net class A and B
I want to set clearances for these net classes with anything not in the class is 120mil. please help me how to set this rule in Altium Designer.
Thanks all,
mairomaster , 02-15-2016, 03:13 PM
Hi syhaunguyen,
If I understood correctly, you want a minimum clearance of 120mil between objects in net class A and all other objects, and minimum clearance of 120mil between objects of net class B and all other objects.
If that is the case, here is how to set up such rule with custom queries:
I am using Altium Designer 16, it might look a bit different with older versions.
syhaunguyen , 02-15-2016, 06:07 PM
Good day to you @mairomaster it's OK now. Thanks you so much.
Once more Q, How to disable check on no-net pad? Picture attach.
mairomaster , 02-16-2016, 12:58 AM
The best practice in my opinion is to put a No-DRC directive to all unconnected pads in your schematics. That also ensures you will not randomly forget to connect a pin and prevents errors/warning during the schematic compilation as well. After placing the directives don't forget to re-compile the project and import the changes to the PCB.
Here is how to place the directives:
syhaunguyen , 02-16-2016, 01:00 AM
Thank @mairomaster
great to know that.
