Footprint primitive pad moving on board
Lakshamana Balakrishnan , 11-10-2021, 02:20 AM
HI Robert,
I am facing some issue Footprint Primitives like pad getting moved while we do update on movement. is there any setttings preferences to fix it by not change.
qdrives , 11-15-2021, 12:07 PM
As @robertferanec mentioned: make sure that the primitives are locked.
amit patel , 11-11-2021, 04:35 AM
May be its moved when you update footprint, because its shown after update foot print.so, check in pcb library when you update.
WhoKnewKnows , 11-12-2021, 05:24 PM
I vaguely remember running into this before. I can't help you with what setting may prevent movement of primitives within a footprint. I can recommend that you use the selection filter according to the task you're performing. EG: If you're only arranging parts on the PCB, you don't really have a need to select primitives within a footprint, so turn off selecting everything you won't need to select. Maybe only have selecting components enabled. Then, when you click anywhere on a component, you'll always select the entire component before dragging. If you have selecting pads enabled, then there's a risk your click and drag will select the pad and move it WRT the footprint.
robertferanec , 11-15-2021, 01:42 AM
This looks like you have primitives for that component unlocked. When you are in PCB, select the component and in the properties panel find: Primitives. Is it locked or unlocked?
Lakshamana Balakrishnan , 11-15-2021, 09:02 PM
Yes as @robertferanec mentioned, Primitives unlocked. Now I rectified it. Thank you so much all of you.
