Pad connection in library!
JohnsonMiller , 11-19-2020, 08:11 AM
In a library and footprint design of a component I need to connect two PADs, I did so but in the PCB and DRC I am receiving a short-circuit error! How we can avoid this error?
goncaloc , 11-19-2020, 11:44 AM
Hi Johnson
Usually I name both pads the same
JohnsonMiller , 11-19-2020, 01:31 PM
@goncaloc , did you check DRC? you most probably will see short circuit error.
WhoKnewKnows , 11-19-2020, 05:51 PM
IIUC, what you're trying to do is done with another type of component called a net tie. I recommend using a net tie component to connect the two nets together, then use the component where you were trying to join them as you would normally.
