polygon clerance
ican7 , 09-08-2015, 06:02 AM
Hi All,
In the attached picture I have a differential pair surrounded by a polygon that is connected to GND net. I would like to set a clearance rule for this polygon so that It's clerance from these differential pair tracks will be 20 mill. I tried to set the clerance rule under the electrical clerance tab in the design rule however then the DRC also complains about the clerance between the tracks. So How would I create a clerance rule that would only affect the distance of the polygon from the tracks only?
robertferanec , 09-08-2015, 06:10 AM
@ican7 please, could you clarify - you are using Altium Designer, right? If yes, I will move the forum there.
ican7, 09-08-2015, 06:15 AM
Hi Robert yes I am using Altium designer 15.1
robertferanec , 09-08-2015, 06:26 AM
Is this what you are looking for?
ican7 , 09-10-2015, 03:05 AM
Do you mean should I also use the polygon cut out between the traces? Sorry I don't get what you mean Robert.
robertferanec, 09-10-2015, 03:10 AM
Moved to: http://www.fedevel.com/designhelp/fo...r-pour-regions
