PCB - Issues with uVias view on specific layers
gmezzina23 , 01-25-2020, 06:11 AM
Hello everyone, I'm using Altium 19.1.7 and I'm doing the fanout for the pad in the below-attached images.
I did the PCB stack-up and I defined a Blind via between L1 and L2 (i.e., Blind 1:2).
Unfortunately, when I place the blind via, it is visible in L1, while it is "hide" in L2 (in monochromatic view). It seems that the uVia does not reach the L2.
Is this a wrong view configuration or what?
Thank you so much in advance!
Sincerely,
GM
chitransh92 , 08-13-2020, 08:49 AM
it seems there is some sort of temporary issue with your version.
May be restarting it should help.
or better update it to the latest.
I tried this on AD20 and it is seen fine for me.
thanks.
qdrives , 08-13-2020, 03:11 PM
Is it perhaps the remove unused pads?
WhoKnewKnows , 08-14-2020, 05:22 AM
You can configure 3D view to show you how the layout is. Altium has this video that shows it
![](https://i.ytimg.com/vi/qFOh7Jn-dOw/maxresdefault.jpg)
Watch to learn how you can setup and use microvias in your next PCB design.See more How To Videos at: https://resources.altium.com/altium-designer-19-how-to-...
robertferanec , 08-14-2020, 07:44 AM
@gmezzina23 is L2 configured as a plane or Signal layer?
