Component change Multi sheet - Hierarchical design in altium
chitransh92 , 06-05-2019, 04:18 PM
Hello all,
I am working with the multi sheet - Hierarchical schematic design in Altium.
Same design is to be repeated twice hence using this feature of the tool. Now my question is : Is it possible to change the component pin number in one of these 2 sheets?
For example: In Sheet A if the 2 pins of a passive component are numbered as 1 and 2 (moving from left to right ), can be changed to 2 and 1(moving from left to right ) in Sheet B of the multi sheet design.
robertferanec , 06-09-2019, 02:40 AM
I believe, if you will be using one block multiple times, the block will be always the same (but I do not use this kind of schematic, so I may be wrong).
If you are using something only two times and it is not big or complex, you can just draw it two times (I sometimes do that).
