Component clearance rule: component and 3D body
przemek , 07-21-2021, 04:00 AM
Hi!
In one of my current projects I need to match board-to-board connectors with an external PCB.
I imported this external PCB as step model and placed it in the desired position.
Now I see Component Clearance DRC between connector P4 and step. This is true for some other connectors too.
Any ideas how could I resolve this? I need a rule for Component Clearance that allows me to have 0 mm clearance between P4 and PCB1R5b step. But I don't know what expressions should be used.
przemek , 07-21-2021, 05:08 AM
I've already found the answer, it turned out quite simple
przemek , 07-22-2021, 04:11 AM
Hi again,
my previous problem was solved, but now I have a similar one, so decided to continue in this thread.
I noticed that 3D Body imported from step file is colliding with my board:
I need a rule that can warn me if collision between 3D Body and PCB can happen.
Query I used is:
but it simply doesn't work.
Any tips appreciated
robertferanec , 07-22-2021, 04:18 AM
I have never used these kind of rules, so it will be interesting to see what you will come up with.
PS: When I am not sure what rule to use, it is super useful to try to build a rule based on "Find similar objects ..." command. Maybe it can help?
https://youtu.be/w9gxB6XVHnkWhoKnewKnows , 07-22-2021, 04:46 AM
Consider that when you accumulate multiple similar rules for a purpose, sometimes you have to tune the priority of these rules 🤷
przemek , 07-22-2021, 05:05 AM
@WhoKnewKnows When I'm testing a rule I always put it on top in priority list to check if it is working
@robertferanec That's a trick I like using. But it doesn't work with PCB in this case. Click on PCB and... nothing happens
![Stick Out Tongue](https://designhelp.fedevel.com/core/images/smilies/tongue.png)
I guess it is associated with Selection Filter, but PCB is not included even in "Other".
qdrives , 07-26-2021, 07:45 AM
How would you have done it in the time when there was no 3D?
Anyhow, you could place a special component, like a fiducial on the places where such collision would occur and have there a little component spacing - ie 0.01mm. You may need to add such small 3D object to the footprint.
przemek , 07-27-2021, 02:22 AM
I have a 3D model generated from an other project so just to make it easier and faster I'd like to use 3D models to check it. However I don't skip double checking in datasheets of the highest components and connectors. Principle of limited trust
You have a good idea with placing fiducial to verify the spacing, thanks!
Use our interactive
